Working with Text
When working with text nodes, there are a lot of things to consider:
- Mixed styles
- Loading fonts
- Missing fonts
Mixed styles
Many text properties can be set on individual characters. For that reason, you will find that many of text properties can return the special value figma.mixed
if there are characters in the text with different values for that property. Always consider that a text property could have mixed values.
Suppose there is a text node that contains the text "hello world". Below are some properties and functions for retrieving the font name:
textNode.fontName // Output: figma.mixed
textNode.getRangeFontName(0, 5) // Output: { family: 'Inter', style: 'Bold' }
textNode.getRangeFontName(5, 11) // Output: { family: 'Inter', style: 'Regular' }
textNode.getRangeFontName(4, 6) // Output: figma.mixed
textNode.getStyledTextSegments(['fontName'])
Output:
characters: "hello",
start: 0,
end: 5,
fontName: { family: 'Inter', style: 'Bold' },
characters: " world",
start: 5,
end: 11,
fontName: { family: 'Inter', style: 'Regular' },
In general, we recommend using text properties such as fontSize
, fontName
, etc... when getting / setting styles for the entire text node, or checking if there are mixed values.
Use the getRange*
and setRange*
functions for getting / setting styles for a specific range of characters. If you want to see what the property values are and which characters they apply to, use getStyledTextSegments
Loading fonts
The important thing with text is that changing the content of a text node requires its font to be loaded and that fonts are not always available. If you attempt to change, say, fontSize
without first loading the font for that text node, the plugin will throw an exception.
When setting the .fontName
or .textStyleId
property, you do only need to load the new font. When setting any other property that affects text layout, you need to load all the fonts that the text node already use. This includes the following properties and functions:
characters
fontSize
fontName
textStyleId
textCase
textDecoration
letterSpacing
lineHeight
setRangeFontSize()
setRangeFontName()
setRangeTextCase()
setRangeTextDecoration()
setRangeLetterSpacing()
setRangeLineHeight()
setRangeTextStyleId()
You do not need to load a font in order to change properties that only affects colors and strokes, such as .fills
, .fillStyleId
, .setRangeFills()
, .strokes
, .strokeWeight
, .strokeAlign
, .strokeStyleId
, .dashPattern
Loading a font is done via figma.loadFontAsync(fontname)
For text nodes that contain a single font, you can call figma.loadFontAsync(node.fontName)
. For nodes that contain multiple fonts you can use the getRangeAllFontNames
API to get all the fonts that the node is using. As an example:
await Promise.all(
node.getRangeAllFontNames(0, node.characters.length)
.map(figma.loadFontAsync)
Missing fonts
You will need to check text.hasMissingFont
before loading a font. If your plugin works with text, do not to ignore this. While less frequent during testing, it's very common in the real world that your users will attempt to run your plugin in a file with missing fonts.
info
How text works in Figma (and why you need to load fonts)
When a user types into a text node or changes one of its properties, we generate a path to represent the text, and store it along with the text node. This way, sharing a file (e.g. to a client) allows them to see the design as-is. Even if they don't have the fonts installed on their system! However, this means that even when a text node looks fine, it may not be editable.
This is one of the many subtleties that Figma needs to do to uphold the core value proposition of a cloud tool: that everyone looking at the same file always sees the same thing.
In addition to this, a font file is not always loaded in memory even when it is available from the user's local machine. This is because font files can be big, there could be many of them, and they aren't needed until text is edited. This makes loading them at startup time potentially very expensive. As such, calling loadFontAsync
is necessary to ensure that the font is available.
Unloaded fonts vs. missing fonts
It is important to note that unloaded fonts are not related to missing fonts. All fonts are unloaded until your plugin loads them by calling loadFontAsync
. Missing fonts are the fonts not available to the user. For example, someone created a text node and this user does not have have the font used in this text node installed on their computer.
