Working with Variables
Variables in Figma design store reusable values that can be applied to all kinds of design properties and prototyping actions. They help save time and effort when building designs, managing design systems, and creating complex prototyping flows.
Use your plugin to interact with variables in Figma, including creating and reading variables. The Plugin API provides methods using the figma.variables
global object to interact with variables.
caution
Variables are currently in beta and subject to change. Learn more: Variables
This guide contains the following sections:
note
This guide assumes that you’re familiar with the basics of creating Figma plugins. If you’re new to developing plugins, check out the Build your first plugin course — you can copy and paste the code from this guide into the plugin you build.
Get variable collections and variables
Use one of the following methods to let your plugin get variables and variable collections.
getLocalVariableCollections
The figma.variables.getLocalVariableCollections
method returns all local variable collections in the current file.
Example usage:
const localCollections = figma.variables.getLocalVariableCollections();
getVariableCollectionById
The figma.variables.getVariableCollectionById
method finds a variable collection by ID. If not found or the provided ID is invalid, returns null
Example usage:
const collection = figma.variables.getVariableCollectionById('VariableCollectionId:257c3beb2/57:13');
getLocalVariables
The figma.variables.getLocalVariables
method returns all local variables in the current file, optionally filtering by resolved type.
Example usage:
const localVariables = figma.variables.getLocalVariables('STRING'); // filters local variables by the 'STRING' type
getVariableById
The figma.variables.getVariableById
method finds a variable by ID. If not found or the provided ID is invalid, returns null
Example usage:
const variable = figma.variables.getVariableById(variableId);
Create variable collections and variables
Use one of the following methods to create variables or variable collections.
createVariableCollection
To create a variable collection, use the figma.variables.createVariableCollection
method.
Example usage:
const collection = figma.variables.createVariableCollection('Example Collection');
createVariable
To create a variable, use the figma.variables.createVariable
method.
Example usage:
const variable = figma.variables.createVariable(
'ExampleVariableName',
collection.id,
'STRING'
This example creates a variable with the name ExampleVariableName
of the STRING
type. The variable is created inside a collection with the ID 57:13
Helpers
The figma.variables
global object also provides some helper methods to make certain operations easier.
createVariableAlias
The figma.variables.createVariableAlias
method is a helper function to create a variable alias. Variable aliases are used to bind variables to other variables, or to bind variables to various properties on a node or style.
setBoundVariableForPaint
The figma.variables.setBoundVariableForPaint
method is a helper function to bind a variable to a SolidPaint.
setBoundVariableForEffect
The figma.variables.setBoundVariableForEffect
method is a helper function to bind a variable to an Effect.
setBoundVariableForLayoutGrid
The figma.variables.setBoundVariableForLayoutGrid
method is a helper function to bind a variable to a LayoutGrid.
importVariableByKeyAsync
The figma.variables.importVariableByKeyAsync
method loads a variable from the team library.
Samples
This section contains some functional plugin samples that use variables.
Example: Authoring a new variable collection
This example creates a new variable collection with two modes, and a color variable that defines a value for each of those two modes.
const collection = figma.variables.createVariableCollection("new-collection")
collection.renameMode(collection.modes[0].modeId, "light")
const colorVariable = figma.variables.createVariable("color-variable", collection.id, "COLOR")
// rename our new variable and collection because naming is hard!
colorVariable.name = "text-primary"
collection.name = "semantic colors"
const lightModeId = collection.modes[0].modeId
const darkModeId = collection.addMode("dark")
// Sets the color to #000 in light mode and #fff in dark mode
colorVariable.setValueForMode(lightModeId, {r: 0, g: 0, b: 0})
colorVariable.setValueForMode(darkModeId, {r: 1, g: 1, b: 1})
Example: Determining if a node is bound to a variable
Variables consumed by a given node are enumerated in the boundVariables
map.
const rectangle = figma.getNodeById(rectangleId)
// rectangle.width is a number
if (rectangle.boundVariables['width'] !== undefined) {
// Width fields can only have one bound variable, but fills and strokes might have multiple.
const widthVariableId = rectangle.boundVariables['width'].id
const widthVariable = figma.variables.getVariableById(widthVariableId)
// At this point we know that `widthVariable` is bound to the `width` property of `rectangle`.
assert(widthVariable.resolveForConsumer(rectangle).value === rectangle.width)
Example: Binding a variable to a node or style
Whether binding to a node or style, the procedure is roughly the same.
const widthVariable = figma.variables.createVariable("width-variable", collection.id, "FLOAT")
const node = figma.getNodeById(...)
// Simple fields can be bound via setBoundVariable
node.setBoundVariable('width', widthVariable.id)
const fillsCopy = clone(node.fills)
// Fills and strokes must be set via their immutable arrays
fillsCopy[0] = figma.variables.setBoundVariableForPaint(fillsCopy[0], 'color', colorVariable)
node.fills = fillsCopy
const style = figma.getStyleById(...)
const paintsCopy = clone(style.paints)
paintsCopy[0] = figma.variables.setBoundVariableForPaint(paintsCopy[0], 'color', colorVariable)
style.paints = paintsCopy
// Effects and LayoutGrids must also be set by their immutable arrays
const radiusVariable = figma.variables.createVariable("radius-variable", collection.id, "FLOAT")
const effectsCopy = clone(node.effects)
effectsCopy[0] = figma.variables.setBoundVariableForEffect(effectsCopy[0], 'radius', radiusVariable)
node.effects = effectsCopy
const countVar = figma.variables.createVariable("count-variable", collection.id, "FLOAT")
const layoutGridsCopy = clone(node.layoutGrids)
layoutGridsCopy[0] = figma.variables.setBoundVariableForLayoutGrid(layoutGridsCopy[0], 'count', countVar)
node.layoutGrids = layoutGridsCopy
Example: Binding a variable to a variant property
This sample binds a string variable to the variant property on a InstanceNode
const instanceNode = figma.getNodeById(...);
const stringVariable = figma.variables.getVariableById(...);
node.setProperties({
"variantPropName":
figma.variables.createVariableAlias(stringVariable)
// To clear
"variantPropName": "Default", // or other string value
Example: Extracting variables from fill styles
Sample code to convert existing styles into variables is available on our GitHub.
Example: Import and export variables
Sample code to help import design tokens from other products or export variables into JSON format. This can further help with migration to variables or syncing design with development. Note that this sample only handles basic import/export and developers are encouraged to extend and customize this code to suit their specific needs.
