Using the Plugin API
As you probably already figured out, the widget API and plugin API are very much related and meant to be used together when building widgets.
The plugin API can only be used in event handlers and hooks.
You can think of this model as:
- The Widget API is an interface to describing what goes on the canvas
- The Plugin API is an interface to manipulate things on the canvas
Consequently, you might find that your widget code looks very much like the following pseudocode:
const { widget } = figma
const { AutoLayout, Text, useWidgetId } = widget
function AverageWidget() {
const widgetId = useWidgetId()
return (
// Use the Widget JSX API here to describe how to render the widget!
<AutoLayout
onClick={() => {
// Use Plugin API here in response to user interactions!
const widgetNode = figma.getNodeById(widgetId) as WidgetNode
<Text>Hello</Text>
</AutoLayout>
widget.register(AverageWidget)
