7 AI for A/B testing tools to ship winning designs
Share 7 AI for A/B testing tools to ship winning designs
You have two versions of a design sitting in front of you, and a sprint review in three days. You know one will perform better, but without the right testing setup, you’re basically just guessing. That’s the problem AI for A/B testing tools is solving for product teams right now.
What used to require weeks of manual setup and statistical wrangling is getting faster, and designers, PMs, and engineers are all feeling the difference.
Read on to learn:
  • What AI brings to the A/B testing process
  • How to build a workflow that takes full advantage of it
  • 7 AI-powered testing tools worth adding to your radar
What AI brings to A/B Testing
Many teams look for alternatives to A/B testing just to avoid the slow, manual process. AI A/B testing changes that by tightening the loop across the entire UX design and experimentation process, from surfacing what to test in the first place to routing traffic dynamically once an experiment is live.
Here’s what that looks like in practice:
  • Spotting the right signal. AI parses user behavior patterns to suggest what to test next, so you’re always working from concrete data.
  • Optimizing on the fly. AI dynamically routes traffic toward top-performing variants mid-run, so you don’t lose conversions while waiting for significance.
  • Testing for more than the average user. It’s easier to run variants for specific segments simultaneously without getting lost in averaged-out data.
  • Cutting out grunt work. Spending less time on manual setup and reporting means more bandwidth for creative problem-solving.
How to use AI in your testing workflow
Getting the most out of AI in testing starts before you run your first experiment. Here’s a step-by-step look at how to use AI for A/B testing.
Step 1: Standardize your design system
AI-powered testing works best when it has a solid design system to lean on. Building your components around design tokens and variables in Figma Design gives AI tools the guardrails they need to generate on-brand, consistent variants.
Every test you run should feel like a real part of your product. With that kind of structure in place, AI can generate and refine variants that still reflect your brand’s logic, making it easier to compare directions and ship the ones that work.
Step 2: Use Figma Make for rapid concept validation
Before committing to a full production build, you want to know your concept works for real users. And fidelity is a bigger factor here than it often gets credit for. Low-fidelity prototypes can be so different from your real product experience that they distract from your test results and undermine their credibility.
Since Figma Make generates prototypes that look and behave like a live experience, you get feedback grounded in reality. The tool generates high-fidelity prototypes from prompts, so you can test flows early and collect meaningful input while there’s still room to change direction.
From there, the strongest states come back to the canvas for refinement. This keeps your designs and validation data in sync, which means fewer surprises once you’re in production.
Build and test faster with Figma Make
Turn a prompt into a clickable, high-fidelity prototype in seconds.
Try Figma Make
Step 3: Connect to an experimentation layer
Once your designs are ready, the next step is getting them into a live testing environment. Most A/B test solutions sync via API or native integration, turning static frames into live test variables.
Think through the handoff early. A tidy design system helps your testing tool read and smoothly swap your design data. This is where the foundation you built in Step 1 pays off.
Once the connection is live, the platform serves variants to specific segments and tracks their performance. The goal is a setup where design and performance data feed into each other in one continuous cycle of improvement.
Step 4: Define automated guardrails
Before you hand off control, define the success metrics and brand constraints that your testing platform should respect. These might include conversion rate thresholds, accessibility and inclusion standards, or visual consistency rules.
Setting these upfront prevents AI from chasing a metric at the expense of the overall user experience. A button color change might boost clicks today, but it could clash with your design patterns or confuse long-time users. Guardrails keep these tradeoffs in check so a short-term win doesn’t create a long-term UX debt.
7 AI for A/B testing tools to consider
The A/B testing software landscape has become much more interesting lately. Here are seven options worth adding to your shortlist:
A/B testing toolIdeal forAI focusData source
Figma MakeRapid concept testingPrompt-to-code mocksFigma canvas
Optimizely OneLarge-scale enterpriseIdea and traffic optimization​​Native SDK / Edge
StatsigDev-driven managementContextual copilotWarehouse native
AB TastySegment personalizationSentiment analysisBrowser / Client-side
VWOAll-in-one CROBehavioral AI insightsClient and server-side
EppoWarehouse-native precisionML model evaluationYour data warehouse
KameleoonHybrid and full-stackReal-time intent forecastingClient and Server-side
1. Figma Make
The Figma Make home page, showing the chat box interface.The Figma Make home page, showing the chat box interface.
Ideal for: Rapid concept testing
Figma Make is a prompt-to-code tool that lets designers and non-technical teammates spin up interactive, high-fidelity prototypes. Describe what you want, and Figma Make generates a clickable experience you can put in front of users right away. The built-in chat interface lets you select any element and prompt changes directly, so the AI collaboration happens inside the canvas.
Within a testing workflow, Figma Make is your concept validation layer. You use it to explore multiple directions and pressure test edge cases before committing resources to a full production build. It’s built for teams that need to move fast without sacrificing the realism required for meaningful user feedback.
Key features:
  • Prompt-to-prototype generation. Turn a text description into a clickable experience in seconds.
  • Design system-aware outputs. The tool uses your existing components and variables to keep every variant on brand.
  • Canvas-ready iteration. Bring generated states back into your main design file to keep refining the work.
2. Optimizely One
The Optimizely One home page, showcasing its product and testimonials.The Optimizely One home page, showcasing its product and testimonials.
Ideal for: Large-scale enterprise programs
Optimizely One handles heavy-duty experimentation across Web, mobile, and backend environments. Teams running high-volume programs use it for the statistical rigor and steady infrastructure needed to scale. You can manage the whole lifecycle, so your experiments and results stay connected as you build.
Optimizely Opal draws on your full experiment history, win rates, and performance trends to surface test ideas grounded in what your program has learned. Once a test is live, it handles the optimization side too, shifting traffic and summarizing results without you having to babysit the process.
Key features:
  • Optimizely Opal. AI that generates test ideas, creates variations, and summarizes results based on your program’s history.
  • Web Experimentation. Run A/B, multivariate, and multi-armed bandit tests with drag-and-drop variation creation and automated traffic distribution.
  • Full-lifecycle coverage. Ideation, targeting, deployment, and analysis in one platform.
3. Statsig
The Statsig home page, showcasing its experiment dashboard.The Statsig home page, showcasing its experiment dashboard.
Ideal for: Dev-driven feature management
Statsig brings together feature flags, A/B testing, and product analytics in one place. Engineering and product teams use it to manage everything from gradual feature rollouts to full-scale experimentation. This keeps the data and the code in the same conversation, which is a huge win for maintaining velocity.
A built-in knowledge graph connects your codebase, feature gates, and metrics. Having that link gives you way more context when you’re trying to figure out why a variant performed the way it did. AI-powered copilot features also help you move through workflows faster by surfacing insights that would usually take an analyst hours to pull manually.
Key features:
  • AI-powered copilot. Surface recommendations and experiment summaries to keep workflows moving.
  • Warehouse Native. Run Statsig directly in your existing data warehouse for full flexibility and control.
  • Feature flags. Ship and test changes gradually with fine-grained rollout controls.
4. AB Tasty
The AB Tasty home pageThe AB Tasty home page
Ideal for: Segment-specific personalization
AB Tasty is a customer experience optimization platform with a strong emphasis on personalization. Rather than running a test, waiting for results, and then digging into who responded to what, AB Tasty factors in individual user behavior and motivation from the start.
Teams that have already defined their user personas will find a lot to work with here. AB Tasty uses that foundation to automate much of the analysis, freeing teams to focus on acting on what they learn rather than manually parsing data after every test.
Key features:
  • EmotionsAI. Segment visitors by psychological motivations to serve more relevant page variations.
  • Evi AI agent. Turn experiment results into clear next steps.
  • Dynamic traffic allocation. Automatically route traffic toward winning variants as tests run.
5. Eppo by Datadog
The Eppo by Datadog home page.The Eppo by Datadog home page.
Ideal for: Warehouse-native precision
Eppo by Datadog sits directly on top of your existing data infrastructure, pulling from the same source of truth your team already trusts for business reporting. This helps eliminate data discrepancies that often crop up when you’re forced to move information between separate pipelines.
Whether you lean on Bayesian logic or sequential testing, you can call winners without second-guessing the results. CUPED variance reduction helps you reach significance faster, while AI model evaluation lets you test against real-world metrics to move past offline benchmarks.
Key features:
  • Feature flags. Fast, resilient flags for A/B tests, feature gates, controlled rollouts, and kill switches.
  • AI model evaluation. Compare model performance against real business metrics in a live environment.
  • Contextual bandits. Automatically explore and optimize variant performance without manual intervention.
6. VWO
The VWO home page.The VWO home page.
Ideal for: Visual-first CRO workflows
VWO has grown from a visual A/B testing tool into a full conversion rate optimization platform. It connects testing, behavioral analytics, and personalization, keeping your data consistent across the funnel.
VWO's AI copilot works similarly to others on this list, but it’s integrated across the entire platform. Describe what you want to test in plain language, and it handles the tracking setup, audience targeting, and design variations. It also digs into behavioral data to suggest new directions for tests that might not have been on your radar.
Key features:
  • VWO Copilot. Generate experiment ideas and build variations from plain language prompts.
  • Predictive segmentation. Automatically identify high-value user groups before a test runs.
  • Codeless visual editor. Create and launch tests directly on your Web pages without any engineering support.
7. Kameleoon
The Kameleoon home page.The Kameleoon home page.
Ideal for: Hybrid and full-stack testing
Kameleoon lets teams run both client-side and server-side tests from a shared environment. Marketing, product, and engineering teams can each work in the tools and workflows they’re comfortable with while staying aligned on data and outcomes.
This tool works well for teams that need to test across both frontend experiences and backend logic without jumping between tools. Kameleoon is also worth noting for teams in regulated industries, as it’s HIPAA, GDPR, and CCPA compliant with a local storage architecture that produces more accurate visitor data across browsers.
Key features:
  • Prompt-Based Experimentation (PBX). Describe a test idea in natural language and launch a live experiment without developer support.
  • AI Predictive Targeting. Forecast visitor intent in real time and serve the most relevant experience automatically.
  • Hybrid experimentation. Run client-side and server-side tests from a single platform without switching tools.
Power your testing workflow with Figma
The right AI for A/B testing tools can speed up how your team learns and ships, but the workflow behind them matters just as much as the tools themselves. Getting your design logic right early makes every experiment easier to manage as you scale.
Here’s how Figma fits into the picture:
  • Use FigJam to map hypotheses and user flows, brainstorm test ideas, align on what to measure, and explore different paths before moving into design.
  • Create a structured source of truth in Figma Design. Build with components, variables, and design system patterns that keep variants consistent and easier to adapt.
  • Use AI and prototyping tools to explore and validate variations. Turn ideas into testable concepts, compare directions, and refine the strongest options before development.
Ready to turn ideas into testable prototypes?
Figma Make lets you generate high-fidelity, clickable prototypes from a prompt—no engineering required.
Get started
Keep reading
  • 6 stages of the product development process
    Learn how to master the stages of the product development process, from concept to launch, and how FigJam can help in this step-by-step guide.
    Learn more
  • What is a go-to-market (GTM) strategy? + How to build one
    A go-to-market (GTM) strategy is your roadmap for launching a product. Learn how to define your target audience and value proposition for a successful launch.
    Learn more
