Prototype & Wireframe
Discover how prototyping and wireframing come together in Figma. Explore the articles below for guides, templates, and best practices.
All articles
  • UX validation: How to stress-test your designs early
    Learn how UX validation helps you spot logic gaps and refine interaction patterns before dev. Use Figma Make to ship dev-ready designs with confidence.
    Read article
  • 10 vibe coding tools for building better experiences
    Keep up with the latest shift in software development using vibe coding tools that allow you to create full applications from plain language prompts.
    Read article
  • No code vs. low code: Key differences and when to use each
    Understand the differences and benefits of no code vs. low code and when to use each approach. Plus, learn how Figma can help.
    Read article
  • How to design an app in 5 steps
    Building an app requires research and constant iteration to meet customer needs. Learn how to design an app effectively and how Figma can help in this guide.
    Read article
  • What is a user flow? Why it’s important in UX design
    Discover the power of a user flow in UX design, plus how to create one with FigJam, examples, and the differences between user flows and other common diagrams.
    Read article
  • What is wireframing?
    Building excellent apps or sites starts with great wireframe design. Apply best practices to your wireframing process with Figma.
    Read article
  • Wireframe vs. mock-up: what’s the difference?
    Wireframes and mockups both play key roles in user-centered design. Learn about their differences, then use Figma’s design tools to get started.
    Read article
  • What is a minimum viable product (MVP)
    Are you asking yourself "what is a minimum viable product" and how does it pertain to product development? Read on to learn more.
    Read article
  • What is prototyping
    Prototyping is the process where teams implement their design to undergo testing. Keep on reading to learn more about what is prototyping.
    Read article
  • What is high-fidelity prototyping—and how can it help?
    High-fidelity prototyping helps you create a detailed UX simulation for usability testing and developer handoff. Learn how to make hi-fi prototypes in Figma.
    Read article
  • Low-fidelity prototyping: What is it and how can it help?
    Low-fidelity prototyping lets you quickly test and validate early-stage design concepts. Learn how to create low-fidelity prototypes with Figma.
    Read article
  • What is rapid prototyping
    Rapid prototyping is a common part of the product development process, but what is rapid prototyping exactly? Read on to learn more.
    Read article
