9 of the best AI prototyping tools to validate product ideas faster
Share 9 of the best AI prototyping tools to validate product ideas faster
When you need to validate a product idea fast, waiting on wireframes isn’t an option. AI prototyping tools have made it possible to go from a rough idea to something clickable in minutes, and product teams are taking notice. According to Figma’s State of the Designer 2026 report, 60% of Figma files created in the last year were made by non-designers, a sign that prototyping has spread well beyond the design team.
The catch is that not every tool works the same way. Some generate polished UI mockups, while others produce working code you can click through in a browser. This guide breaks down nine of the best AI prototyping tools and what each one is built for, so you can find the right fit for your workflow.
Read on to learn:
  • A breakdown of 9 tools across the full fidelity spectrum
  • How to choose the right tool for your team’s needs
AI prototyping toolIdeal forKey features
Figma MakeExploring multiple prototype directions before committing to a buildPrompt-to-prototype, multiplayer canvas, design system context, editable code output
LovableValidating a full-stack product conceptFull-stack generation, GitHub sync, visual editing
v0 by VercelGenerating production-ready UI componentsText/image-to-UI, React/Next.js output, shadcn/ui components, Vercel deploy
BoltRapid full-stack prototyping without any local setupIn-browser IDE, multi-model support, Figma and GitHub import
UX PilotEarly-stage UX explorationText-to-wireframe and hi-fi generation, Figma integration, predictive heatmaps, and UX review
RelumePlanning website structure with AI-generated sitemaps and wireframesAI sitemap generation, wireframe generation, Figma export, component library
BananiVisualizing multi-screen Web apps and complex user journeysMulti-screen flow generation, prompt-based iteration, Figma-ready export
Claude DesignGenerating a quick first draft or proof of conceptDesign system ingestion, functional React components, direct code handoff
Google StitchRapidly iterating on UI through voice and codeVoice-driven iteration, production-ready code export, agent-friendly design systems
1. Figma Make
Figma Make homepage, showing the AI prompt box.Figma Make homepage, showing the AI prompt box.
Ideal for: Exploring multiple prototype directions before committing to a build
Figma Make is an AI prototyping tool that turns natural language prompts into functional, interactive prototypes your whole team can build from. Start with a prompt, refine visually, and adjust the underlying code when you need more control. Because prototypes live on the Figma canvas, your team can pull up multiple directions side by side, react in real time, and align before anyone commits to a path.
Since Figma Make pulls in your team’s existing components, colors, and typography, prototypes look and feel like your actual product. That means you’re validating real experiences, not generic mockups. And because the output lives in Figma, it’s something you can build on all the way to production.
The Supabase integration lets you connect real data, user authentication, and backend functionality so you can validate full user flows. When you’re ready to hand off, the MCP server and Code Connect bring your design intent directly into the development workflow.
Key features
  • Prompt-to-prototype generation. Describe your idea in plain language, and Figma Make generates a functional, interactive prototype ready for team review.
  • Multiplayer canvas. Multiple team members can comment, react, and iterate on prototypes in real time without switching tools.
  • Design system context awareness. Figma Make pulls in your existing components and styles so every prototype reflects your product.
  • Editable code output. Adjust the underlying code directly for more precise control over the prototype’s behavior and structure.
Go from prompt to prototype in minutes
Figma Make transforms your ideas into interactive prototypes so you can validate them before committing to full development.
Get started
2. Lovable
Lovable homepage, showing the AI prompt box.Lovable homepage, showing the AI prompt box.
Ideal for: Validating a full-stack product concept
Lovable is a conversational AI platform that generates Web applications from natural language prompts, covering frontend, backend, database, and authentication in one workflow. Describe what you want to build, and it scaffolds the entire structure, including pieces you don’t explicitly specify.
Lovable Cloud handles database, authentication, and file storage natively through Supabase, so you can validate user flows with real data without connecting external tools. When you’re ready to hand off, the code exports to GitHub in standard React and TypeScript, so any engineer can pick it up and extend it.
The main tradeoff is that Lovable operates independently from your design system. Prototypes will be functional, but they won’t reflect your product’s look and feel, which often means rework downstream when designers and developers sit down to build.
Key features
  • Full-stack generation. Builds frontend, backend, database, and authentication from a prompt with no external configuration required.
  • GitHub sync. Code exports in standard React and TypeScript, making developer handoff straightforward.
  • Visual editing. Click directly on any element to adjust text, colors, spacing, and layout without writing additional prompts.
3. v0 by Vercel
v0 by Vercel homepage, showing the AI prompt box.v0 by Vercel homepage, showing the AI prompt box.
Ideal for: Generating production-ready UI components
As a frontend development tool, v0 by Vercel generates production-ready React and Next.js code from natural language descriptions. The output follows modern frontend best practices, producing components that developers can drop directly into an existing codebase. v0 consistently produces clean, consistent interfaces and deploys directly to Vercel in one click.
Backend logic, authentication, and databases require external tools, and there’s no shared canvas or real-time commenting, so review and iteration happen outside the tool. It’s a strong fit when you need a polished UI design to validate a concept before handing off to engineering.
Key features
  • React and Next.js code output. Every generation produces production-ready frontend code that developers can use directly.
  • Sandbox runtime. Import GitHub repositories and pull environment variables to build and preview applications in a real environment.
  • One-click Vercel deployment. Push prototypes live instantly with automatic SSL, CDN, and serverless functions built in.
4. Bolt
 Bolt homepage, showing the AI prompt box. Bolt homepage, showing the AI prompt box.
Ideal for: Rapid full-stack prototyping without any local setup
Bolt is a browser-based AI development platform that generates full-stack Web applications from natural language prompts. Under the hood, it runs a full Node.js environment directly in your browser tab via StackBlitz WebContainers, so there’s nothing to install and no configuration before you start building. Describe your idea, and Bolt scaffolds a complete full-stack application in seconds.
Speed is Bolt’s defining quality. A built-in visual editor lets you tweak layouts and styling without touching the code, and you can drop in a Figma design or GitHub repo as a starting point. Like v0, Bolt is primarily a solo experience with limited real-time collaboration, so it works best when one person is driving early exploration rather than a whole team reviewing together.
Key features
  • In-browser full-stack environment. Bolt runs a full Node.js runtime in your browser tab, so you can build, preview, and iterate without local setup.
  • Multi-model support. Choose from Claude and other leading AI models, with adjustable reasoning depth to balance speed and output quality.
  • Figma and GitHub import. Drop in a Figma design or existing codebase as a starting point to build with real context from day one.
5. UX Pilot
Homepage for UX Pilot, an AI prototyping tool.Homepage for UX Pilot, an AI prototyping tool.
Ideal for: Early-stage UX exploration
UX Pilot is an AI tool that takes you from low-fidelity wireframes to high-fidelity screens in one workflow. Describe what you need, and it generates structured layouts, connected user flows, and polished UI, all built on a model trained specifically for UI/UX. It adapts to your design system, integrates with Figma, and exports code for developer handoff.
UX Pilot works in both directions with Figma, so you can push new designs over or bring existing files back in for analysis without disrupting your current workflow. It also includes predictive heatmaps and automated UX reviews that flag usability issues before anything gets handed off to a developer.
Key features
  • Text-to-wireframe and hi-fi generation. Generate structured wireframes and polished high-fidelity screens from a natural language prompt, with no manual layout work required.
  • Figma integration. Push designs directly to Figma or pull existing files back into UX Pilot for analysis, keeping your existing workflow intact.
  • Predictive heatmaps and UX review. Automatically flag usability issues and friction points before handoff, so teams catch problems earlier in the process.
6. Relume
Homepage for Relume, an AI prototyping tool.Homepage for Relume, an AI prototyping tool.
Ideal for: Mapping out Web information architecture
Relume specializes in building the structural backbone of a website. Feed it a project brief, and it generates a sitemap, so you can map out page hierarchy and user flow before any styling begins.
Once the structure is set, the tool builds out wireframes using a library of over 1,000 responsive components. This library-first approach means the generated layouts are grounded in proven Web design patterns, giving you a solid foundation for the next stage of design.
To move to high fidelity, you can sync these wireframes directly into Figma Design. Relume also connects to Webflow and React, making it a flexible starting point for teams that want to keep planning and to build tightly connected.
Key features
  • AI sitemap generator. Convert a project brief into a visual map of every page and section to establish a site’s hierarchy.
  • Library-based wireframing. Transition from sitemaps to layouts using a massive library of professional, responsive Web components.
  • Multi-tool sync. Move your site structure into Figma Design, Webflow, or React to keep the design and development process fluid.
7. Banani
Homepage for Banani, an AI prototyping tool.Homepage for Banani, an AI prototyping tool.
Ideal for: Visualizing multi-screen Web apps and complex user journeys
Banani turns a prompt into multi-screen prototypes, which is useful for visualizing complex onboarding or dashboard flows. You provide the vision, and it generates a functional starting point that captures the logic of the user journey.
The tool uses a credit-based system, so every generation or edit uses a bit of your monthly allowance. Once the flow feels right, you can move everything into Figma Design as editable layers with auto layout.
Key features
  • Multi-screen flow generation. Input a project brief to create a sequence of screens that map out an entire user experience.
  • Prompt-based iteration. Use follow-up prompts to refine specific parts of the UI, from tweaking copy to adjusting the visual style.
  • Figma-ready export. Sync your screens directly to Figma Design as editable layers that respect auto layout and hierarchy.
8. Claude Design
Homepage for Claude Design, an AI prototyping tool.Homepage for Claude Design, an AI prototyping tool.
Ideal for: Generating a quick first draft or proof of concept
Claude Design is Anthropic’s dedicated visual workspace for generating UI from natural language. Connect your brand assets or documentation, and it generates screens that match your product. Since the output is production-ready front-end code, you can move directly into Claude Code or export as a clean HTML file.
The main limitation is that there’s no multiplayer canvas or real-time collaboration, so review and iteration happen outside the tool. It’s a capable option for generating a first draft fast, but less so for teams that need to explore multiple directions and carry work all the way to production.
Key features
  • Design system ingestion. Link your brand guidelines or codebase so the AI sticks to your established styles and tokens.
  • Interactive React output. Generate functional UI components that respond to user inputs for more realistic prototype testing.
  • Direct code handoff. Pipe your designs into development tools like Claude Code to turn visual ideas into working software.
9. Stitch
Homepage for Stitch, an AI prototyping tool.Homepage for Stitch, an AI prototyping tool.
Ideal for: Rapidly iterating on UI through voice and code
Google’s Stitch is an AI-native design canvas built for the experimental parts of a project. Brief the AI on the high-level intent of your work, and watch it build high-fidelity screens in real time. It’s useful for rapid prototyping, letting you jump between sketches, text, and voice commands as you explore directions.
The standout feature is the integrated design agent powered by Gemini. You can talk to your canvas to request critiques or quick variations, like a glassmorphic style for your dashboard. Stitch produces structured components and clean React or Tailwind code rather than flat images. You can also export your design rules as a DESIGN.md file so other AI agents can follow your styling in future sessions.
Key features
  • Voice-driven iteration. Speak directly to the canvas to request real-time design changes, layout critiques, or component variations.
  • Production-ready code export. Generate clean, functional React and Tailwind CSS alongside your visuals to speed up the move to development.
  • Agent-friendly design systems. Export your design rules using DESIGN.md to keep styling consistent across different AI tools and projects.
What to look for in an AI prototyping tool
Choosing the best prototyping tools for your workflow is more about your build process than a long list of features. These practical details will help you find the right balance between speed and control for your next project.
Fidelity level
Fidelity is the first decision in any prototype. A low-fidelity prototype works well for testing a basic flow while keeping the focus on structure. When it’s time to nail the visual direction, high-fidelity prototyping helps everyone picture how the final product will look and feel.
Tools like Figma Make help you jump straight into high-fidelity interactions and UI patterns. Pick the level that answers your immediate questions so you can keep the project moving.
Code output vs. design output
Most AI tools for prototyping focus on one of two outputs: design files or working code. Design-centric tools give you a canvas to polish layers and visual styles with precision. Code-centric tools generate live, ready-to-run logic for the browser or a developer handoff.
Figma Make sits at the intersection of both. It uses your existing components and styles to generate layouts that mirror your live product, so your early prototype stays connected to the real thing as you iterate on the details inside Figma Design.
Design tool integration
Many AI design tools live outside your main design environment, so your early explorations stay disconnected from production files. The more handoffs between tools, the more context gets lost along the way.
Because Figma Make is native to your design environment, generated prototypes land directly on the canvas as editable layers, so the work your team reviews stays the same work that moves forward into production.
Iteration speed
Iteration speed comes down to how many ways you can refine an output. Follow-up prompting lets you adjust direction conversationally, visual editing lets you tweak layouts without touching code, and direct code editing gives you precise control when you need it. Figma Make supports all three paths in one place, so you can move between them as the work evolves.
Team collaboration
AI-generated prototypes are only useful if the right people can react to them. Most tools generate something you can screenshot or share via a link, but the review process still happens outside the tool, where it quickly loses context.
Figma Make keeps that conversation inside the work, so teammates can leave comments and iterate together. Product managers, engineers, and designers can all weigh in without anyone needing to export a file or schedule a separate review session.
Go from prompt to prototype with Figma Make
AI prototyping tools have made it faster to explore ideas, pressure-test concepts, and get the right people aligned before any real dev work begins. The best fit depends on your fidelity needs, your team’s workflow, and how closely you need your prototype to reflect the product. For teams that want all of that in one place, Figma Make is a strong place to start.
Here’s how to put it all together:
  • Start in FigJam to map out flows and align your team before jumping into a prototype.
  • Browse prototype templates to give your next build a head start.
  • Check out the Figma prototype generator to add interactions and test user flows with something that looks and behaves like your product.
  • Use Figma Design to refine and iterate on your designs once you’ve found the right direction.
  • Switch to Dev Mode to hand off your finalized designs to engineering with accurate specs and code references.
Ready to prototype faster?
Figma Make turns your prompts into functional, interactive, well-designed prototypes.
Get started
Keep reading
  • How to use AI for product design: 7 use cases
    Learn how to use AI for product design 7 different ways. Turn your ideas into working prototypes faster with prompt-based design and collaborative creativity.
    Learn more
  • Usability testing: The key to designing with confidence
    Usability testing turns feedback into design clarity. Learn all about its benefits, methods, and how to run effective tests with help from Figma.
    Learn more
  • 11 of the best AI design tools for 2026
    Find some of the best AI design tools for 2026. Compare tool capabilities and benefits to streamline your design process and boost your creativity.
    Learn more
  • AI in design: Transforming the way we create
    Curious how AI in design is changing the way teams work? See how tools like Figma make it easier to bring ideas to life with real-world examples.
    Learn more
  • 10 real-world vibe coding examples to jumpstart your AI workflow
    Explore 12 real-world vibe coding examples that show how to build apps from prompts. Learn a workflow to turn your best ideas into functional prototypes instantly.
    Learn more
  • What is user experience (UX) design? Process + principles explained
    UX design is the creation of digital products around user needs and expectations. Learn key principles, skills, and how to use Figma for UX design.
    Learn more
